G'Gay All,
Ok.... I have got serious and installed a DVD Drive into my PC and will be used to take copies of various titles.
The unit is a 4KUS unit.
I first istalled the unit into the PC this morning (using WinXP) and started the PC. I placed 'DVD Decrypter' on the PC and placed a DVD into the drive. All went ok with no reported problems.
Thereafter I installed 'WinDVD' then re-ran DVD Decrypter and now have an error message popping up saying:
ASPI Initialisation Failed
Error: ASPI manager was not found on system.
I have since removed WinDVD and reinstalled DVD Decrypter but still get the same error message.
How can I get things back on track again ??
Best Regards
Pete![]()
Please install this tiny utility
and try again
ASPIINST.EXE from
WWW.ADAPTEC.COM
also if you're in ME or 95 try
aspitool.exe
ASPI Reset Tool for Windows 95/98/Me. Copyright(C)2001 B.H.A. Corporation. -
G'Day dcsos,
Went and had a look at the ADAPTEC site and it dosen't show a ASPIINST.EXE unless they have decided to rename it.
Pete
PS: I'm running under WinXP. -
This is for you PETE
http://www.adaptec.com/worldwide/support/drivers_by_product.html?cat=/Product/ASPI-4.70
if this don't work under XP...get this free ware instead of the DECRYPTER
http://www.riphelp.com/downloads/smart-ripper.html
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 11:40 -
DVD authoring failed, advice?
By Elevenius in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2011, 14:06 -
8gb dvd burning failed
By renz_007 in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2011, 09:08 -
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 18:07 -
DVD File Allocation Failed
By Emeraldas in forum Newbie / General discussionsReplies: 8Last Post: 22nd Sep 2007, 08:26
